http://www.ebay.com.au/itm/Evga-nforce-790i-ultra-775-rare-/170713773195?pt=AU_Components&hash=item27bf55748b
$152.50 + $20postage
australia postage to australa You might get these on Ebay im not sure which country you are in this might guide you to one you could get this on Ebay if you dont have an account you will need to create one Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account when you get to the paypal login page at the bottom you will see new to paypal sign up tab paypal to create an account paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress http://www.paypal.com/ be very specific when you type in the search always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described you will even see the pictures of your item so you cant make a mistake and get them home delivered hope this helps you
The battery could be worn out and needs replacing or the charging circuit in the phone is faulty or the charger is faulty. Try another Sony charger to determine if it is faulty. Then try another battery. If none of these work then it may be cheaper to get a new phone on another plan..
If its charging on your computer,then the problem is the charger itself.
The first thing to do is try to check you charger and its terminal,pins might not in align or corroded,otherwise buy original sony ericsson charger.Also check the charging terminal of your phone. you can clean it using brush or a pin and scratch each portion so that the power voltage will some it.
Hard to tell but very likely. If the power was on or the was still holding a charge when the card was removed or replaced it could have something to do with it.Try removing the drivers and re installing them.Here is a direct link to PDF manual for the motherboard.
no, it wont. Dell notebooks have proprietary components and configurations, and using another motherboard will not work, it wont fit, it wont interface with the connections, and it wont make you happy. If you want to get a gaming machine, buy an alienware device, or, (if you wanna get out a little cheaper) go to the Dell outlet, and get a refurbished Dell Studio XP. you can get one with a 2200 64 bit dual core CPU, 4 gigs ram, and 320 gig hdd for about $620 after fees etc.
Hi playboyalive, to answer your question! (Yes) the,
XFX nForce 790i Ultra SLI Motherboard will support Intel's core i7 extreme edition multi-core 3.2GHz CPU. The board can go higher. The highest tested by XFX is Intel's 3.73 GHz multi-core CPU. You can see all supported CPU's at the XFX link below; http://www.nvidia.com/content/nforce700i/nForce_Intel_CPU_List.pdf
