HP Officejet Pro L7680 All-In-One Printer Logo
Posted on Jun 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Faxing multiple pages
Hi
I am trying to fax muliple pages.....but can only fax 1 page at a time from the glass scanner....can you help please ?
trying to fax multiple pages from the glass, but makes me dial # each time...
Anonymous
Level 2:
Novelist:
  • Expert 106 Answers
  • Posted on Jul 11, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
106
Questions
0
Helped
54120
Points
202
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
When I fax multiple pages, they have a black strip down the entire page
Lift the scanner cover and you will see a see-through piece of glass or plastic on the left hand side, this is the section it uses to scan from the Automatic document feeder. Make sure this is clear and free from marks or it will affect the result of multiple document scanning or faxing.
Hope this helps, if so please rate my response. Thank you for supporting the FixYa Community
Regards GM
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
1helpful
Faxing more than one page from glass.
You should be able to load the pages into the top "feeder" on the printer / scanner / fax. I think the needed to be loaded face up if I remember correctly. From there, you can dial the number, and hit fax, it should start to **** in the pages one at a time until they are all faxed.
Hope this helps!
Tim
1helpful
Faxing issue
To my knowledge, you can only fax multiple pages from the printer itself. Place the fax page on the glass, press "fax" ,then press "black" or "color" after doing this to all the pages, press "ok" They have now been sent. I am assuming that you have your phoneline connected correctly to the printer. You should be able to hear it on another phone extension when your fax modem dials.
1helpful
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
1helpful
FAXING MULTIPLE PAGES
you can use the automatic docu feedr at the top of the machine to fax multiple pages just put all the pages you want to scan on that feeder then do the usual faxing steps
If it's only one page.. just place it on the glass face down.
When faxing muliple pages you must place them in the automatic document feeder located on top of the machine.
Place all originals print side up (up to 35 pages). A message will show up in the display letting you know original were loaded up properly. Let me know it this helps.
2answers
Multiple page faxing
press fax then press faxtel nummer . put page 1 on the glass press start mono (b/w mono) You will be asked if there are another pages. Press 1  and put the next page onto the glass. When finished press 2 (No, no more pages). machine will start calling and sending.
BTW Did you read the handbook? This is explained within the handbook which can be downloded from the brother homepage of your country!
Faxing
You can't. The only way to fax more than one page at a time is through the document feeder. You can fax all the pages at one time using your software, but you'd still have to scan each page into your computer from the glass one at a time.
k24674
Grand Canyon Tech
Grand Canyon Tech
