Welcome to Fixya
Error e2-02 means machine is having error of lifting motor assembly for tray #2. You may check the tray. Sometimes there's just a paper clogged at the rear of the paper tray. Just remove the 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
still i have this problem there is no 2nd tray as technician sugest i re-installed the printer but still problem there toner and spanner red light lit steady not comming to resdy mode scanner working copier printer not working error e03-02 comes with check printer message comes
