Well it sounds like the fuse is broken and needs to be replaced then 1.5 amp ico fuse for the Super Nintendo console I think that kijijiji and eBay sell these fuse types for SNES consoles the fuse will have to be soldered on and solder the old one off first too. If you don't fell comfortable with fixing it find a place that fixes old consoles or find some one that can fix it for you or just buy a new console
Well it sounds like the fuse is broken and needs to be replaced then 1.5 amp ico fuse for the Super Nintendo console I think that eBay sell these fuse types for SNES consoles the fuse will have to be soldered on and solder the old one off first too.
Well it sounds like the fuse is broken and needs to be replaced too
SOURCE: how to fix my nintendo (NES) without replacing anything
Yes, this is a 72 pin connector problem. The connector has become dirty or oxidized and needs replacing or cleaning. Problem can usually be solved by buying a NES console Pin cleaner which inserts like a game. The "Eliminator" is one which works great wet or dry to eliminate this problem.
SOURCE: Nintendo NES Repair
Hi sounds like your console has a weak connector pin and is lsing contact with your game. I fixed mine buy purchasing a new connector pin from www.gameoz.com.au and it included step by step instructions with photos and a few tips on how to clean NES cartridge games as their is no use in installing a new 72 pin connector if you dont properly clean the NES games because installing dirty games into a new connector pin will result in console blinking flashing again.
SOURCE: I have a Nintendo Nes-001 with the RC Aedapter
Here is a link to a website that has a text only version of the nes manual. Hope it helps.
http://www.atarihq.com/tsr/manuals/crtldeck.txt
SOURCE: whenever i turn on my NES the power light blinks
Hi sounds like the common fault found with these old retro consoles. Flashing light is mostly because the system does not make good contact with the game. which may be because of a worn out connector pins in side the console or dirty games recommend cleaning all your games with a game cartridge paste cleaner and replacing the connector pin with a new one. see http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/ they carry these items and included photo instructions.
