I am using D101 intel board but when I install windows 7 or windows vista the hanging problem starts with these operating system.I have 1.50 GB of RAM too.Kindly suggest what to do.
i've tried it but it doesn't work u can only run windows vista or windows 8/8.1 smoothly with a PCI-E GPU installed!i've tried it but it doesn't work u can only run windows vista or windows 8/8.1 smoothly with a PCI-E GPU installed!
You can't post conmments that contain an email address.
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that
matches your Windows operating system.
Please click on this link andselect your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Hi Trifon, you are detecting a known problem for 32 bit operating systems. The problem for those system is that they can manage maximum 3 Gb of RAM. If you want all of your RAM used you have to install a 64 bit operating system. Windows 7 has also a version for 64 bit as well as windows xp (but is not good supported) and windows vista.
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements
Operating System
For Windows®-based PC Requires a PC that meets the requirements for and has installed one of these operating systems
Processor
Windows® 7 Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista® Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free
Windows® XP with Service Pack 2 (SP2) or later Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free
Other
CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones
Internet
Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require
Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
check for the win 7 drivers , run in safe mode and restore to early point, and install one by one the drivers, download registry cleaner reg in out to clean registry errors
mostly all drivers will get through updation of windows 7. if its not solved. then go to intel website. find your specific model no to download latest drivers.
It is probably because your internet connection is slow or you lack bandwidth. You have a fast computer and if you've wiped the hard drive and reinstalled windows then its unlikely that it is a windows problem. Also if you're using a modem instead of a dedicated connection they do tend to be rather slow managing only up to 56k per second.
