SOURCE: HTC PPC-6800 Vista driver and/or WMDC install problem
hey u need to install windows mobile device center first, not its update, on ur vista, as activesync cannot be installed on vista...
download it from
http://www.microsoft.com/windowsmobile/devicecenter.mspx after a validation check..
SOURCE: Don't have Active Sync
you must go and download active sync from website.And install it to your computer.
SOURCE: quero ascessar a internet sem usar o gprs apenas
I want use my gmail and I can't do it, if you can help me please
SOURCE: my HTC touch T3232 wouldn't
I can think of some actions to play with (in case you have not already taken them, that is):
1) on your phone, go to 'Start > Settings > Connections tab > USB to PC' and toggle the 'Enable advanced network fucntionality' checkbox, i.e. it it is checked, uncheck it; otherwise, check it. Try to connect, then restore that setting to its original value and try again;
2) For security reasons, backup your PIM first (you could just copy file 'pim.vol' on the root of your phone to your SD card, to be copied back to the rooot of your device later). Then, delete the sync partnership, both on your phone and PC and try to set it up again;
Please, let me know if I can help you any further.
Regards,
Carlos
SOURCE: no puedo conectar mi htpc
Aqui esta el manual, la informacion que nesecita se encuentra en la pagina 127: Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendacion para mi respuesta. Gracias, Jose
http://www.scribd.com/doc/16932430/HTC-Mogul-PPC-6800-User-Guide
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
