You can transfer contacts from Android to another Android phone quickly via Bluetooth, Samsung smart switch or with third party
phone to phone data transfer tools
SOURCE: my mobile phone is the
restart your phone into original settings..
if not happen..try to press 3,#,call and the switch
i'm not sure with this..
if no choice bring you phone to repair shop & they format or flash it
thanss....
Frank
SOURCE: Cant copy phonebook contacts from sim card to phone memory?
Go this way
Menu > Phonebook > Options
Scroll down to Move and select.
Select Multiple from the pop out.
In the list just check All or whatever contacts you want.
HTH
SOURCE: how can i transfer my contacts from nokia phone to my HTC Touch
There are few tools to have. A usb cord, your PC has Bluetooth and pair with you N51 via bluetooth. Have the free software, "Nokia PC Suite". Download it from www.nokiausa.com/PCsuite. It's a free download. Once downloaded, restart your computer. (without the phone connected) Connect. It'll give you easy step by step instructions to transfer contacts to the computer. Plus, other multimedia you may have on your device. Very handy!! Then, just use Active Sync or any software you got with your HTC Touch HD. It can sync you contacts from Outlook onto the new phone. This is nice, in case your phone would crash, break, or the worse stolen. Your contacts are all backed up on the PC.
Always take a look at www.htcwiki.com for the best tips & tricks for your HTC device and software updates. A lot of times they will even post known issues and work arounds.
SOURCE: Hi. I am trying to transfer my phone contacts
I would suggest you to use computer inbetween for transfer as it takes very less time. Otherwise you need to send phone book contacts one by one.
With the computer, just export all your contacts from Samsung to Outlook and then import it to HTC. I did the same when I wanted to transfer contacts from my Nokia phone to Samsung.
Hello The easiest way I found: On your nokia go to contacts>markall>copy to memory card then go to setting>file manager>change the mobile tab to card tab>click on other>click on contact that you have save before> mark all>click on send>bluetooth(before this step you have to switch on the HTC bluetooth)fallow instructions .it takes a little time but all your nos. go to HTC and will be saved to its contacts. Good lock. no need of pc suite or outlook
