Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The nails keep jamming; getting stuck half way out the nose of the gun. Happens every 2-3 shots. Very frustrating.
Anonymous
Level 2:
Novelist:
  • Expert 178 Answers
  • Posted on Dec 05, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
178
Questions
0
Helped
76197
Points
480
Hello Holly, either you are using the wrong nails, or the nailer's driver is worn, causing it to skip over the head of the nail. If this unit has a spring loaded "door" on the front of the nose, its possible the spring has lost its strength, allowing the nose to partially open during operation. Without knowing the brand and model of the nailer, I can only speak in generalities, but I would think the best solution is either the first two problems.
1helpful
2answers
Duofast df225c 2 nails jam how to repair
Make Sure that you're not using corrode it rusty stick nails as that looks like a stick nail gun. So they can become dirty that is the gun many times I would use a carburetor cleaner or something that will clean something such as tar from a stick gun or a roofing and look at that and try that
Two nails jammed in the hitachi NR83A how do I get them out
The only way that I have been able to remove really stuck driver is to remove the head and cylinder so that you can place the body of the gun against piece of wood (this will prevent the head from cracking) with nose of gun pointing up. Then Use a broken driver blade ground narrower to allow for stuck nail to pass and strike with large brass hammer.
2answers
Ridgid coilnail gun jams and safty jams in place and gun will not fire. also somtimes will jam
if safety is jamming, its either bent or the pin that keeps it in place is missing/broken, you can find the pin right in front of the trigger. now as far as the nails jamming could be a few things. 1. wrong nails 2.right nail but may have gotten a defective batch 3. bucket that holds nails is adjusted to wrong size. 4.nails have been dropped/ squished and coil is not round anymore 5. nose is very worn and two nails are trying to come out at a time 6. driver is worn/broken and is trying to push out two nails at one time
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
2helpful
Jammed nail gun fc350a
Nail guns will jam when driving nails thru very hard wood, solid objects, allowing the gun to double fire hitting the first nail or using the wrong nails(amoung some of the reasons, you get the idea that jamming is common) . There is no special tool to help in case of jam. You must be creative. I use an old driver shaft from nailer that easily fits into the nose of the gun (you can grind a piece of allen wrench to fit into nose and allow space for the stuck nail). The metel that you use must be very hard and strike with heavy copper or brass hammer (caution, steel hammer may splinter metal, use protective gear ). You will need to strike very hard to remove some stuck nails. If first or second strike results in no movement of driver, remove the head and cylinder of the nailer and place the body of the gun squarely on piece of plywood over concete floor (this will protect the head of the nailer from being damaged). Worst case, you will need to remove the rails. Good luck.
I keep reading how my Porter Cable FN250B has a quick release nose to clear jammed nails, but I cannot figure out how to open it.
My fn250b has a small tab/lever just below the nail feeder (with no nails in the gun the lever will be just below the nail pusher). Push on the lever with your thumb and the nose will open. This lever is held in place with one screw. If the tab/lever breaks off at the screw or if the screw falls out the lever and its spring will fall off and the front nose will just be loose/ nails will be pushed out. If someone rigged a part to keep the nose closed, you can order the correct parts at www.toolpartsdirect.com. Not really needed however because the gun does not jam that often. Good luck
1helpful
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
2helpful
Bosch nail gun jamming and i cant get the nail out.
Sounds like the quickest way is to take the nose off. Remove The bottom 4 bolts. Pull back the nail pusher first and latch, so the magazine spring do go flying.
Once you have the nose off, then you can put in a vise and pound thru the other way.
Thanks,
Jeff
2answers
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
Top Campbell Hausfeld Air Tools & Compressors Experts
john h
ZJ Limited
ZJ Limited
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
