SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
SOURCE: KitchenAid Dishwasher KUDS01IJ will not
couple things you can try first hold down cancel for ten seconds this usually cancels the cycle and puts the unit in the drain function or you can try hit high scrub and than energy saver and repeated the same after a few seconds or if this also doesnt work then you could also try shutting of the power by way of the breaker for 5 minutes which usually causes the controler to reset if none of these tests work message me back and we can perform other tests also how many times are the lights blinking if its 3 times then these tests should correct the problem if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Hi
Press and hold the HEATED DRY/NO HEAT DRY/AIR DRY button for
15 seconds to unlock the control lock in your dishwasher. Also make sure that
nothing is blocking the drain pump assembly. If the issue returns after its
cleaned then it means that the control board has gone bad and should be
replaced. Hope this helps...please post back for further assistance.
Daniel
