The ice maker in my Kenmore Side by side stopped working. It was replaced about 2 years ago. It will not fill with water. The shut off arm is in the proper position and the water dispenser in the door works.
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Often I find your ice maker on the Kenmore side by side thefill tube frozen. The fill tube is ablack rubber hose located above and to the right of your ice maker. Simplypinch the tube to see if it frozen solid. If it is, use a hair dryer set onmedium to defrost the fill line. http://www.on-timeappliance.com/kenmorerefrigeratorrepairdallastx.html
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
make sure you have strong water pressure to the frig.
Do the ice maker have a shutoff arm? or a shutoff switch? either way make sure it is on. by now there should be water in the icemaker tray. if not then manually pour 1/2 cup of water into the icemaker. if it does make ice then replace the water fill valve.
if there is ice still in the ice maker tray you still have to check the water fill valve before we can say the icemaker doesn't work.
need a meter to check the continunity of the water vavle. if the valve is open repalce valve, if there is continunity the the valve is good.
hope this is helpful. if you cant do this ask a friend who is an electrician to help you
there could be a blockage of frozen water in the fill tube of the ice maker.
if there is no blockage then the nex thig to check is the main water valve that supplies the water to the ice maker.
you can check the power from the main pcb board to the ice maker and make sure you have current to the ice maker
if all else fails replace the ice maker
i hope this has helped in some way good luck
if the cubes are small the water valve may be bad. Also pop the cover
off and see if there is a plastic tab laying loose in the cover . It
should have 2 holding the center plastic gear on if only one is in the
center the ice maker is bad. Also make sure to change your filter ever
6 to 8 months if you have one this will stop other problems.
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
If it overfills and drips, look for an
adjustment behind the plastic endcover with a +/- on it. - is less water. If it continuously drips, replace the water
inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze.You can take the water
line off the valve and watch to see if it drips.
Hi and I hope this will help. You can manually turn the timer and see if any water is dispensed into the ice cube tray . If no water is dispensed check if the valve is any good . A solenoid in the valve opens to allow water in to the ice maker. Sometimes timers stick too.
If The ice maker has completely stopped producing ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
