Question about Sony DVP-NC85H Multi-disc DVD Player
I just bought my dvd player used without an remote went to use it and everything was in another language. I want to know how can i set it to english without the remote or having to buy one?
  • mrquick757 Dec 05, 2010
    well the remote is not an option. i need a way to do it on the panel.
  • 8,197 Answers
Sorry you will need to remote to change the settings. You can get the manual on the link below if you do not trust me.
http://www.riverparkinc.com/techpdf/DVPNC85H%20owners%20manual.pdf
You can get the remot on the link below.
http://www.remotes.com/store/sony/dvpnc85h.html
Posted on Dec 05, 2010
  • Sony Master
  • 11,800 Answers
You need the remote. This is the procedure: start the player with no disk in it; press Enter to run the Quick setup when a message appears on the screen; press Enter to go in the language settings and in there select english; press Enter till you get out of the quick setup. You can always go back and redo it if you want to change something else.
Full user manual http://www.docs.sony.com/release/DVPNC85H.pdf
  • Azrael SRL Dec 05, 2010
    You can't do it without the remote - the necessary buttons can be found only on it.
SOURCE:
Without a remote, how can I change language from English to Spanish?
How Do I Set New Preferences with My Blu-Ray Remote ...
www.ebay.com > ... > DVD & Blu-ray Players
To reset your Blu-ray player to its factory settings, you cannot use a remote. ... Press 1 on your remote for English, 2 for Spanish, or 3 or French. ... If subtitles are notavailable in the language you selected, they will simply disappear during ...
How do I adjust subtitles, captions and alternate audio on ...
https://help.netflix.com/en/node/372
NetflixAlternate audio changes the language of the content you stream or changes your audio to 5.1 surround sound. ... To save or adjust your subtitles and captions settings, play a TV show or movie ... TV and iOS devices must be done on the actual device, not the website. .... Most Blu-ray players, Smart TVs, and Set-top boxes.
[PDF]Operating Instructions Blu-ray Disc Player DMP-BD655 ...
ftp://ftp.panasonic.com/bluray/om/dmp-bd45_mul_om.pdf
Panasonic
Dec 21, 2015 | Televison & Video
How do I change language on Samsung DVD without remote?
Check your manual or player settings when there is no disc in, there should be a default language setting as well as subtitles default on/off/language
default meaning it would select the preferred language on movie play without having to use remote to change it.
Dec 15, 2012 | Televison & Video
A disk in a series of exercise discs plays only in Spanish. My young daughter had the remote and, in a few quick buttons, made the language and writing change to Spanish only and I cannot, no matter what I...
The problem is not the disc itself but your DVD player. If other discs still play in English, and it is just this one disc that plays in Spanish, then your player is using some sort of stored setting to recognize your preference for spanish on that particular disc.
Forgive me if you've already done this, but try turning unplugging the DVD player for a period of ten seconds or so, and then plug it back in. If there is a reset button, press it. See if the disc still plays in Spanish after that.
If so, you may need to navigate the DVD menu of the offending CD to turn off the language setting your daughter selected. If you don't speak Spanish, try navigating to the language settings on one of the other discs with the English menus. Memorize how you got there, and take the same path through the Spanish language menu. Return the language setting to English, and exit.
Hope this helps.
Jun 09, 2011 | Koss KS4110 DVD Player
How do i change the language from spanish to english on the insignia remote
Press the Setup button on your remote control to enter the on screen menus. Using the remote's navigation buttons, scroll to Language Settings, then Display Menu to set your preferred display language. The owner's manual can be found here for more details.
Dec 17, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
French langauge is programmed into a Koss DVD model KD 260-2. No remote. Would a universal remote help me change this DVD player to play in english?
I'm sure you can find a universal remote that will let you change that setting, but you'll have to look around. The cheap ones do NOT let you change very many setting, especially Language setting. Check electronic stores and associates and I'm sure you'll find one that'll work.
May 25, 2009 | Televison & Video
My friend went into my settings and changed the language to China
菜单 设置 语言 英语
Menu Settings Language English
Thats a translation if your SanDisk uses symbols for chinese to change it back to english.
May 19, 2009 | SanDisk Sansa Clip MP3 Player
I cannot change the language settings on the dvd
switch on your dvd player and with the remote press the setup button. go to the general page and it will give you the option to set the OSD language. you can set it there in english ^_^
Mar 29, 2009 | Televison & Video
I have a toshiba DVD Video player SD-4000KU2. I'm watching a movie which has an audio in English but the menu is in French. I would like to know how to change the menu to English. Thanks
Use your remote to access the set-up menu. It will ask you what language you prefer for on-line menus. It might read "idioma". Scroll through the menu options until you find on-screen language,. then select English.
Dec 03, 2008 | Toshiba SD-4000
Language
Press Setup on the remote.
The third entry is Display. Go to it and press OK
The first entry is language. Press OK. The first entry in English. Press OK. You should now be in English.
Jul 08, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG DP271 language settings
ok first go to menu then go to language settings then click english
Mar 05, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Sony DVP-NC85H Multi-disc DVD Player Logo
361 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
