Broderbund PrintMaster Platinum Logo
Posted on Nov 08, 2017
Setup stopped just before the end. However the program seems to be loaded onto my system. However when I try to start it up I get the following message......... "Cannot launch JAVA application" Uncaught exception in main method: java.lang.NoclassDefFoundError:com/install4j/api/launcher/StartupNotification$Listener"
2 Related Answers
Anonymous
  • Posted on Dec 24, 2009
SOURCE: I have Windows 7 and just installed PrintMaster
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Testimonial: "Thanks for your help. The regional setting fixed the problem. Great holidays to you. Marc"
speedyfs
Franky Pierre
  • 14 Answers
  • Posted on Apr 27, 2011
SOURCE: PrintMaster 2011 Platinum <3.0.70> encountered
Hello, I had the same issue, I found this article http://support.encore.com/technicalsupport/kb.aspx?kb_id=1250&product_id=2643 It pretty much says that your regional setting is not set to English United States. Changing that will resolve the issue. Under Control Panel > Regional Settings.
I want to fix itunes in my cell
1. Insert the driver installation CD into the computer, then wait for the installation wizard to load onto the screen.
2. Click "Next" on the welcome page, then follow the prompts of the installation wizard to completely setup the driver onto the computer.
3. Plug the USB data cable into the power port on the side of the Motorola RAZR V3 cell phone. Connect the other end into any USB port on the computer system.
4. Click "Start," "(My) Computer," then double-click the removable device icon. Select the "Music" icon to load a window with all the music saved on the cell phone.
5. Click-and-drag the music from your computer into the open window. You are able to copy over any audio track from a system media player, such as Windows Media Player or iTunes (open the program, then click-and-drag a track into the window). Repeat this process with any other audio file.
6. Close out the open windows, then right-click the removable device icon and select "Eject." Disconnect the Motorola RAZR V3xx from the computer once the icon disappears.
2answers
When i start my pc today, i had stop 0x0000007b (0xf9e48528 0xc0000034 0x00000000 0x00000000) i try with chkdsk /r end fixboot but no result.
When you start your computer, you may receive one of the following error messages:
  • STOP: 0x0000007B (parameter1, parameter2, parameter3, parameter4)
    INACCESSIBLE_BOOT_DEVICE
  • Setup has encountered a fatal error that prevents it from continuing.
    Contact your product support representative for assistance. The following status will assist them in diagnosing the problem.
    (0x4, 0x1, 0, 0)
    Setup cannot continue. Power down or reboot your computer now.
You may also receive a "Stop 0x0000007B" error message during Windows XP Setup when the Setup program restarts during the installation process. When you receive a Stop error while the Setup program is running, you receive the second error message. To troubleshoot this issue, read the following four sections to determine if any one of the issues applies to you. If none of the issues apply to you, use the following general troubleshooting steps at the end of the article. uparrow.gifBack to the top Boot-Sector Viruses You may receive a "Stop 0x0000007B" error message if your computer is infected with a boot-sector virus. If the problem is intermittent and you can start Windows, check your computer for viruses. If you find a virus, also check any floppy disks for viruses before you use them again.
For a list of antivirus software manufacturers, click the following article number to see the article in the Microsoft Knowledge Base: 49500 List of Antivirus Software Vendors Note You may have to use more than one brand of virus-detection software to detect and remove various viruses.
Important If your computer has been infected, it may be open to additional forms of attack. We recommend that you rebuild infected Internet-facing servers by following the guidelines that are published on the CERT Web site. Internet-facing servers are servers that function without a firewall or other protection. It is also a good idea to rebuild any other computers that are at risk because of their proximity to infected computers before you put them back in service.
If a virus has infected your Windows XP-based computer and a virus-detection program cannot remove the virus and repair the system, you must repartition and format your hard disk and reinstall Windows XP. For additional information about partitioning and formatting a hard disk with Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk in Windows XP For more information about how to help protect the boot sector from viruses in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 122221 How to protect boot sector from viruses in Windows uparrow.gifBack to the top Device Driver IssuesYou may receive a "Stop 0x0000007B" error message in the following scenarios:
  • A device driver that the computer boot controller needs is not configured to start during the startup process.
  • A device driver that the computer boot controller needs is corrupted.
  • Information in the Windows XP registry (information related to how the device drivers load during startup) is corrupted.
Windows XP requires a miniport driver to communicate with the hard disk controller that is used to start your computer. If Windows XP does not supply a device driver for your controller or if Windows XP is using a corrupted or incompatible driver, you must replace the driver with a valid copy that is compatible with your controller and Windows XP.
During the first phase of the Windows XP installation, Setup displays the following message at the bottom of the screen: Press F6 if you have to install a third-party SCSI or RAID driver. Press F6 and then follow the instructions to install a mass-storage device driver from your Original Equipment Manufacturer (OEM). For additional information about using F6 to load an OEM device driver to support, click the following article number to view the article in the Microsoft Knowledge Base: General Troubleshooting If none of the issues that have been described in this article apply to you, use the following general troubleshooting steps:
  1. If you receive one of these error messages while you are installing Windows XP, update the computer BIOS or obtain Windows XP drivers for your hard disk controller (from the manufacturer of your computer, system board, or hard disk controller), or do both. For information about how to update your computer's BIOS or obtain Windows XP drivers, contact your computer manufacturer. For additional information about the availability of drivers, see the Device Driver Issues section in this article.
    Note: If Windows NT 4.0 or Windows 2000 was installed previously on a mirrored boot partition, see the Other Issues section in this article.
  2. Use the Last Known Good Configuration feature. This may resolve the problem if you recently installed an incompatible device driver for your boot controller. For additional information about using the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 How To start your computer by using the Last Known Good Configuration feature in Windows XP
  3. Use the Repair option with Windows XP Setup. For additional information about repairing Windows XP by using the Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 315341 How to perform an in-place upgrade (reinstallation) of Windows XP
  4. Restore a registry backup. For additional information about restoring a registry backup, click the following article number to view the article in the Microsoft Knowledge Base: 307545 How to recover from a corrupted registry that prevents Windows XP from starting
1helpful
2answers
Message kb953691 as I download
If you are installing the software from the Web, and if the program stops responding (hangs), the program may be unable to connect to a server to download files. You must be connected to Internet to install the software. Depending on your Internet connection, the setup may take 15-20 minutes to finish.
You may notice that the installation process seems to get stuck in a loop, and seems to reinstall some components. This is typical behavior. However, if the setup stops or seems to get stuck in a loop for more 30 minutes, the server may be down or may be experiencing other problems. In this case, you may have to restart the setup, try again later, or try again the next day.
If the same thing happens, you can try the following steps :
Set Microsoft Internet Explorer as the default browser
loadTOCNode(2, 'resolution');
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click to select Make Default on the Programs tab, and then click OK.
  4. Restart Internet Explorer.
  5. Click Yes if you are prompted with the following message: Internet Explorer is not currently your default browser. Would you like to make it your default browser?
  6. Exit Internet Explorer.
    Note You must complete these steps to install the software. After the install is complete, you can switch back to a different default browser if you prefer.
Would like to load some of the older games i have onto vista but they are not 64 bit compatible, looking for free download to correct this problem
Run the Program Compatibility Wizard
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
Hi i am having trouble with our wma58, the last 2 washes it has sounded noisy on start up but then washed fine yesterday i put the machine on it seemed to get half way through a cycle then stop all the...
Try the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the filter inside the hose.
Remove the black hose onto the pump, and check for blockage or obstruction here and in the pump.
Hopefully, this will solve your problem.
Good luck.
Assist with an Operating System start issue? PC is a Gateway GT5228
the following will re-install windows without destroying your stuff but you must follow it exactly !!!!!!!
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" height="21" alt="To setup Windows XP now and Repair Install , press ENTER." src="http://www.michaelstevenstech.com/note.gif" width="15" border="0" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
  7. good luck beergut707
My computer is trying to configure and load windows photo gallery but it keeps saying I do not have the CD Rom I do not want to load this program I cannot seem to cance it and when I go into remove...
  • Click Start .
  • In the Start Search field, type msconfig, and press Enter.
  • The System Configuration window opens.
  • In the General tab view, select Selective Startup, and remove the checkmark next to Load startup items.
  • Click on Startup TAB
  • Under Startup TAB uncheck all of the Items except Following:-
  • For Windows Vista
HD Audio Control Panel.
HP KBD EXE.
Hp digital imagine - hp all-in-one series.
HPRun.
Hpsysdrv.
HP Total Care Advisor.
Microsoft Windows Operating System.
NVIDIA products.
Symantec Technologies products.
Windows Defender.
  • For Windows XP, do not disable the following startup items:-
Alcxmntr
Atiptaxx
ati2mdxx
Backupnotify
Ccapp
Ccregvfy
HPBootOp
Hpsysdrv
Kbd
LTMSG
NvCpl
ps2
Recguard
VTTimer
  • Click the Services tab, select Hide all Microsoft services, and click the Disable all button.
  • Restart the computer for the changes to take effect.
  • After the computer restarts, a message appears confirming some startup programs have been blocked from opening.
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
