Question about Nikon D100 Digital Camera
Error code eFF - Nikon D100 Digital Camera
    Genius:
  • 1,273 Answers
Did you mean Fee error code ?, if so see:
http://support.nikonusa.com/app/answers/detail/a_id/2605/~/what-does-the-fee-or-f---error-message-displayed-on-an-slr-camera-mean%3F
Posted on Dec 05, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
This normally indicates that you're using a lens with an aperture ring, and the ring is not locked in position. Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if the lens has a lock. Control the aperture from the body, just as with a lens without an aperture ring.
If the lens doesn't have an aperture ring, could you reply to this post and specify what lens you do have on the D100?
2 Suggested Answers
SOURCE:
  • 100 Answers
SOURCE: Error code eFF
hey,
which lens are you usuing?
it means that the F is not set, and you neet to set in manually. usually there is a tiny button in the backside of the lens.
Posted on Jun 25, 2008
Which email address can i use we need help from EFF?
Please us below mentioned emails.
info@eff.org and press@eff.org
Thanks
Sep 10, 2018 | Computers & Internet
I need to pass emissions and have 4 codes to solve.
Your doing your own diagnostics?
The codes are on the internet
Aug 15, 2014 | 2005 Toyota 4Runner SR5 V8
Stumble @ 30-40 MPH under ligh acceleration
Problem sometimes is with cheap parts they are bad.Good wires,good plugs,good coils.
May 05, 2013 | 2004 Mitsubishi Endeavor
P=160 r=30 s=11000 eff=1
<span class="sectionbodybold">P= 160 R= 30 S= 11,000 Eff= 1 </span>
Aug 20, 2010 | Heating & Cooling
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Goodman high-eff furnace, 115 BTU/hr. The fan runs constantly but it has stopped blowing warm air. I'm getting 6 flashing lights as error code. What's this mean?
Remove the lower panel and look for a wiring diagram pasted to it. On that diagram there will be an error code diagnostic chart. Depending upon which model you have it could be an open overheat switch caused by a dirty filter or a bad fuse.
Feb 13, 2010 | Goodman GMS90703BXA Heater
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Eff error when connecting lenses AF 50 mm 1.8 D to d300 and f stop not on 22. Camera works only when stop at 22.
That particular lens could be bad, try taking it back and get a replacement one.
Nov 26, 2009 | Nikon Cameras
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code eFF
hey,
May 19, 2008 | Nikon D100 Digital Camera
Nikon D100 Digital Camera Logo
313 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
