Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a new printer head printer 3250 - Kodak EASYSHARE 5300 All-In-One InkJet Printer
  • Anonymous Jul 13, 2019
    Start getting paid every month online from home more than $15k just by doing very simple and easy job from home. Last month i have earned $17954 from this online job just by giving this 2 hrs a day using my laptop. I am now a good online earner. Get this job you guys also and start earning money online right now by follow details here......................===>>> www.gocash7.com++
    Don’t copy "++" with web address
JDTec
Level 3:
  • Kodak Master 4,338 Answers
  • Posted on Dec 06, 2010
JDTec
Kodak Master
Level 3:
Answers
4338
Questions
0
Helped
2127847
Points
14653
We've determined that the printhead for your printer may be in need of replacement.
We will review your service history to determine if your printhead usage suggests that another course of action is required to solve your problem. To expedite this process, please complete the mandatory fields below. If we determine that a printhead replacement is necessary, the new printhead will arrive within 3 to 8 business days.
NOTE: If a mandatory field is incomplete, shipment of a new printhead will be delayed.
Kodak Service Number
(7-digit number located under the printer access cover) Call Kodak: All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How do you clean the printhead
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
4helpful
How do I clean the ink heads of the ESP3250PP ALL-IN-ONE
For ESP 3250, 5250, 5210, Office 2150, 2170, 6150, 7250, 9250, C110, C310, and C315 printers:
  1. Press Home on the printer control panel.
  2. Press the down arrow button until Maintenance is selected, then press OK.
  3. Press the down arrow until Clean Printhead is selected, then press OK.
Thanks!!
EJ Kudelka
3helpful
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
3helpful
2answers
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
2answers
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
1helpful
Kodak esp 3250 printer applemac 10.6 os airport express. printer tries to print but no print appears on paper
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
2helpful
My printer keeps sayon my black ink cartrige needs replacing but its a new cartrige
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
10helpful
2answers
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
