Cell Phones Logo
Posted on Jun 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia volume i have a nokia 6234 and the volume button is broken how can i turn the volume up without it
  • Kain187 Mar 17, 2009
    Both volume buttons don't work ... could anyone help pls ?
    .Kain
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
541
Points
8
Hi.  I had a similar problem but only the down volume buttonw worked (which meant that my volume was at 1 but I couldn't get it to go any higher).  If you are able to use one of the volume buttons, press it once to take you to the voulme control screen; then use the centre button to conrol up and down using left and right.
Anonymous
Level 1:
  • Posted on Aug 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
541
Points
I had the same problem and did what Andrew suggested and it worked
Anonymous
Level 2:
  • Expert 161 Answers
  • Posted on Jun 27, 2008
Anonymous
Expert
Level 2:
Answers
161
Questions
Helped
53661
Points
411
Try having its casing changed. If you attempt to remove the volume button and poke the inner button to adjust the volume using a needle, it could work but would most likely cause damage and make things worse.
2answers
My Nokia 6234 is not accepting my sim card, i need Restriction code, my IMEI number is 359395002773712
your phone is lock
try these sites
http://www.gsmliberty.net/shop/nokia-6234-imei-unlock-codes-p-1758.html
http://sim-unlock.net/simlock/Nokia/6234/
RESTRICTION & MASTER CODE FOR NOKIA 6234. IMEI-359395003537405
Hi, To which network has your Nokia 6234 been locked to? The safest and easiest way to unlock a mobile phone is to unlock using unlock code. An unlock code for a Nokia mobile phone can be obtained either from the respective network provider or from any trusted vendor online. for example, An accurate unlock code for a Nokia 6234 can be obtained from www.simpleunlocking.com/nokia-6234/rs16wp9/ at affordable cost. This site provides accurate unlock codes for over thousands of mobile models at low cost with easy unlocking instructions.
UNLOCKING STEPS FOR NOKIA 6234
1 - Switch on your Nokia 6234 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6234.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6234 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6234 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6234
The master reset for a Nokia 6234 can be done through any Nokia Priority dealer.
Oct 22, 2012 • Cell Phones
Nokia 6234 restriction code
Hi,you can try Simpleunlocking.com to get restriction code for your Nokia 6234 and get it unlocked..
3helpful
2answers
Recently my n73 phone has fallen on the ground and after this the volume button for up has been broken. this means i can only lower the volume or zoom out or any other thing that i can do with these...
No need to ask for software as well as tricks.I thought that there is no way to increase without changing the broken broken button .My comment is to contact mobile repairing shop.But it is up to you.Good luck.
My nokia 6234 is blocked and is requesting for the security code how can i get a master security phone code,without using the imei code.
Kindly note that,12345 is the factory master code for nokia. If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Kind regards, Jay__BNVHC
24helpful
3answers
How do i reset my nokia 6234?
i have nokia 6234.i want to restore factory settings.but i have not its security code.
Nokia 6234 sound to soft
If you are reffering to the sound during a call, then all you do is push the 12:00 position on the dial type button(multifunction switch) and that wiill increase the volume. If you are reffering to a video playback then yes the sound is way too low and the only solution is a headphone set. Thanks, Dana
2helpful
2answers
Nokia 6234 Security Code
Hi
Its 12345 . For more information refer to the user manual for Nokia 6234 from the following link :
http://nds1.nokia.com/phones/files/main_page/Nokia_6234_Vodafone_UG_en.pdf
Thanks
Rylee
2helpful
2answers
Master Security code for NOKIA 6234
dear customer thanx 4 choosing fixya....
ur master code is 7106773734
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
