Question about E-Machines T6520 PC Desktop
I am trying to find the power switch diagram for an emachine t6520 thanks
    Scholar:
    New Friend:
  • 70 Answers
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
Posted on Apr 11, 2014
SOURCE:
Joed911
  • 4338 Answers
SOURCE: I have an emachines t6520 and the power sw wire, HDD led wire, and the power led wire hve been disconected
On the system board, on the left edge next to the primary IDE connector, there is a 9 pin header.
I usually get a magnify glass and look down on the header . From right to left,you will see PWR led pins closer to the edge of the motherboard.and the Power BTN next to it.(the side of the pins that has 4 pins on it)
Then on the other side, you will see the pins for the HDLED across from the PWR led. Then the Reset pins across the PWR BTN.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 02, 2008
  • 1383 Answers
SOURCE: Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Posted on Jul 04, 2009
SOURCE: Need correct MOB location for power switch on emachine W3410.
what kind of motherboard did you change..?
try to search in the internet.. just type the name of the board and including the diagram.. sample.."ASUS MOTHERBOARD POWER DIAGRAM"...
Posted on Jul 17, 2009
gotgeek2
  • 565 Answers
SOURCE: need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Posted on Nov 30, 2009
Testimonial: "Thanks, have a good one!"
graemevm
  • 519 Answers
SOURCE: EMachines Power Switch
Rather than hunt for a diagram, take a metal conductor and short out the prongs two at a time until you find the two that turn on your PC. It is 100% safe to do this as you CANNOT damage the motherboard by shorting out the wrong prongs.
Best wishes,
Graemevm
Posted on Dec 21, 2009
Emachine tower powers on disk drives open and close, there is no picture on the screen. how to fix?
Is the monitor plugged into the wall and power turned on?
Is the video output of the PC connected to the monitor?
Feb 09, 2015 | Quantum Technology eMachines eMachines...
Radeon 6570 graphics card any reported problems with emachine T6520
Yes as long as your T6520 comes with at least a 400 watt power supply. It has the required 16x PCI Express slot.
Feb 19, 2013 | E-Machines T6520 PC Desktop
Looking for manual for rs480m motherboard
Try this one:
http://productsmanuals.com/computer-manuals/ecs-rs480-m-motherboard-manual
Feb 16, 2012 | FIC AU13 Chameleon Motherboard
I need the wiring diagram that shows where on the motherboard to plug the power switch ,power LED, and HDD Led on a T6520 emachine desktop
Most Motherboards are made to only accept certain plugs in that specific spot! If you are trying to add something new like a new Fan or LED, or HHD and you need power you would have to use a 4 prong plug off the power supply, If your power supply does not have any more available plugs, Amazon.com or Newegg.com sells splitters!
Good Luck and Best Wishes!
May 03, 2011 | Computers & Internet
Prior to installing the radeon 4550 video card i followed the instructions and disabled the onboard video adapter via the device manager. I have the emachine model T6520. After disabling the onboard...
Hello
Try reseating the video card in the pci slot,remove completly then reinstall.
Also check your monitor video cable for being tight.
Last..Does this card require 24 volts? check for a 4 pin adaptor plug on the card.It may need its own power.
Apr 22, 2011 | E-Machines T6520 PC Desktop
Have emachines t6520 need to know power switch connectors and led etc. go on motherboard
There should be white text next to the front panel connector on the motherboard labeling which connector goes where. this may also help:garthok.gif
Apr 07, 2011 | E-Machines (308714) Motherboard
I need the diagram for the motherboard that is installed on my emachines model t6520. Do you know where I will be able to find one?
I Goggled your model and came up with this website: http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T6520
Jan 04, 2011 | E-Machines eMachines Desktop PC
Jul 04, 2009 | E-Machines eMachines Desktop PC
Apr 27, 2009 | Computers & Internet
E-Machines T6520 PC Desktop Logo
183 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
