1)On handset, press MENU, 0, 0, 1.
Handset display shows as fsystem error #1 Panasonic kxtg2770 - ts_hsinset_locator.gifg src="/uploads/images/ts_hsinset_locator.gif" alt="ts_hsinset_locator.gif" class="h_mi" />
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until tsystem error #1 Panasonic kxtg2770 - ts_hsinset_hsregistering.gifs follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective.system error #1 Panasonic kxtg2770 - spacer.gifnd your unit for service.
Panasystem error #1 Panasonic kxtg2770 - spacer.gifices Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
Handset display shows as follows.
2) On base unit, press LOCATOR fsystem error #1 Panasonic kxtg2770 - ts_hsinset_hsregistered.gifD flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Sersystem error #1 Panasonic kxtg2770 - ts_hsinset_mute.gifmer Servicenter
McAllen, TX 7850
1) Press FUNCTION on handssystem error #1 Panasonic kxtg2770 - ts_hsinset_hsregistering.gifr key, press Down (V) 4 timessystem error #1 Panasonic kxtg2770 - spacer.gif) 1 time, Down (V) 7 times, Right (>) 2 times.system error #1 Panasonic kxtg2770 - ts_hsinset_hsregistered.gif as follows.
2) On base unit, press MUTE. (MUTE LED flashes.)
