Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
The remote only turns TV off and on. Cannot adjust volume or change input source to DVD. The TV buttons soes not work. Cannot change the input source or volume
the problem is clearly NOT with the remote. NONE of the buttons on the TV work except the ON/OFF. the problem is clearly NOT with the remote. NONE of the buttons on the TV work except the ON/OFF.
The Hisense EN-31603A remote's buttons doesn't work how can I change it back to the origanal source?The Hisense EN-31603A remote's buttons doesn't work how can I change it back to the origanal source?
AnonymousMar 23, 2014
Westinghouse LD 3265Westinghouse LD 3265
You can't post conmments that contain an email address.
Re: mintex 37 inch wide screen. remote is working however...
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Are all of the sub-menus besides the clock unavailable or just the ones related to OTA (RF) signals? If it's just the OTA menus that are missing, change the source/input to TV. On all of my TVs, the channel scan option and related functions are blocked if the current input is not TV.
Changing the input/source depends on the TV. First make sure that an antenna or cable source on an RF (RG-59/RG-60 cable) is connected to the set. Next look for a Source or Input button on the original remote. Press this button. On some models, you navigate through the menu by pressing the Input/Source button repeatedly and then press OK to change the input. On other sets, you navigate with the arrow keys and then press OK. Some TVs may switch to the new source after a few seconds without any button presses; they don't need the OK button to be pressed. On a universal remote, you may find an Input/Source button but the button may not work with some codes for the manufacturer. (This can be frustrating since the basic functions (power, channel up/down, volume up/down) work; try a different code.)
Some TVs will also have an Input/Source button on the TV. This will work like the button on the remote. Use the Select button for the OK button. A few TVs have the option inside the on-screen menu. Press Menu and then look for a source option in a Tools or Setup menu.
I hope this helps. I have never had a TV where only the Clock menu is available. If that is the case with your TV, I don't know of a solution.
try setting the tv to channel 3 or 4. if that does not work, try finding a "input" or "source" or video" button on the remote and cycle thru them, this should get you back up and running. remember to have the cable box turned on during this so youll see when it comes back on.
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv.
I hope this helps!
-Der Strom
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
njdb,
Look on the remote for keys that are labled tv/vcr or source or input... In fact, if you go to the front of the unit - that's a Sanyo right - find the grouping of buttons that change the channel, volume etc.. There should be a button marked source or input there.. Press it as many times as it takes to get back to the input source your cable is on...
If you have any problems let me know...
Bill
same problem
same problem.
buttons remote inputs
