VeriFone (M19755014US1) Magnetic Card Reader Logo
Posted on Dec 04, 2010
System mode entry password - VeriFone (M19755014US1) Magnetic Card Reader
legitech
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Jan 28, 2014
legitech
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
5
Questions
0
Helped
1553
Points
11
Hello, we can provide a modified software/firmware for verifone with offline mode also with fully specifications including SDK source codes, contact us at [email protected] for more details.
2005 chevy impala car alarm fuse
What about it ? Need more details .
Content Theft Deterrent (CTD) Description and Operation
The CTD system (when armed) is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 2 minutes when an unauthorized vehicle entry is detected. However, the CTD system does not affect engine starting.
An unauthorized entry can be any of the following with the CTD system armed:
• Forced entry into the passenger compartment.
• When any door is opened without being unlocked by using the key to unlock either of the front doors or the UNLOCK command from a Keyless Entry Transmitter.
• Forced entry into the rear compartment.
The components of the system are:
• Keyless Entry Module (Remote Control Door Lock Receiver)
• Door Ajar Switches
• Body Control Module
• Front Door Lock Cylinder Switches
• Power Door Lock Switches
The CTD system is an internal function of the Body Control Module (BCM) which utilizes class 2 serial data and various switch input information to perform CTD functions. When the BCM detects an unauthorized entry, it activates the horns and exterior lamps. The BCM has five basic modes (disarmed, standby, delayed, armed, and alarm) for operating the CTD system. The different modes are described below.
The BCM has the CTD system in a disarmed mode until the following conditions are detected:
• Ignition key turned to the OFF position.
• Any door open.
• Doors locked by either the power door lock switch or the LOCK button on the transmitter.
The BCM enters the standby mode when the above conditions are detected. In standby mode, the BCM commands the SECURITY indicator to flash. If all the doors are closed and the LOCK button on the transmitter is used, the BCM enters the delayed mode.
When the last door is closed, the BCM enters the delayed mode for 30 seconds. In delayed mode the BCM commands the SECURITY indicator to illuminate ON steady.
After 30 seconds, the BCM enters the armed mode. Any forced entry activates the alarm mode.
When the BCM detects a forced entry, the BCM enters the alarm mode. The BCM activates the horns and exterior lamps for 2minutes. This is followed by a three minute time-out with the horn no longer active. If no new intrusions are detected after the time-out, the horn is not active.The system must be disarmed or the intrusion condition removed after the time-out for the system to exit alarm mode .
There are no fuse's for the alarm , there are main power feeds to the BCM .
1helpful
How to disable a car alarm on a G6 pontiac 2008
Content Theft Deterrent (CTD) Description and Operation When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected. However, the CTD system does not affect engine starting.
• When any door is opened without first being unlocked using the UNLOCK command from the keyless entry transmitter
• Unauthorized entry into the underhood area (if equipped)
• Unauthorized entry into the rear compartment
• After a battery reconnect, if the battery was disconnected with the CTD system armed
The components of the CTD system are:
• Body Control Module (BCM)
• Remote Control Door Lock Receiver (RCDLR)
• Security indicator
• Door ajar switches
• Rear compartment lid ajar switch
• Hood ajar switch (if equipped)
Arming the CTD System
Use the following procedure in order to arm the system:
Place the shift lever in P (park).
Turn OFF the ignition.
Open any door.
Important: The system is not armed if the doors are locked manually; the remote keyless entry transmitter must be used to arm the content theft deterrent (CTD) system.
Lock the doors using the LOCK button on the transmitter. The system is in standby mode and will not start the arming timer until all doors are closed.
The system will begin the arm sequence immediately after the last door is closed. If the keyless entry transmitter is used to arm the system after the vehicle doors are closed, the arm sequence will begin as soon as the LOCK command is received by the transmitter.
Locking the Vehicle Without Arming the CTD System
Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following:
- Press the UNLOCK button on the keyless entry transmitter.
- Insert a valid key into the ignition and switch to the ON position.
• To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event):
I need a system code, or password for installing the new t-con board. I took TV to a repair person and I purchased the T-Con Board because the repair man said that was the problem. Now the repair man is...
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Problem: tamper system mode entry password
Password protection was installed by the dealer. You must take the radio to an authorized dealer for reprogramming.
How do I reset the password on a verifone omni 3200?
To prevent the unauthorized use of System Mode functions, the Omni
3200 terminal firmware requires that you key in a System Password
each time you enter System Mode.
The default System Password, which is pre-set at the factory, is:
[1] [ALPHA] [ALPHA] [6] [6] [8] [3] [1]
Note: For terminals that do not yet have an application program
stored in their memory, password entry is not required to enter
System Mode. Simply press the [CLEAR] key when the message
DOWNLOAD NEEDED
is displayed.When you key in the correct password, the terminal enters System
Mode and the System Prompt is displayed. The System Prompt
consists of two parts: the word
SYSTEM=
and the terminal's
firmware version ID, in
VPQXXYYZ
format. (For more information
about the System Prompt, see the section entitled "The System
Prompt" below.)
In System Mode, you can the select a procedure to change the default
password to a unique and more secure password. When you set a new
System Password, be sure to keep a copy of the new password in a
secure place.
A valid System Password may consist of from one to ten
alphanumeric characters. You can change the system password at any
time, provided you know what the current password is.
When you key in the System Password to enter System Mode, an
asterisk (*) appears on the display for each character you type,
obscuring the password you are entering from general view.
However, when you press the [ALPHA] key as part of a System
Password, no asterisk is displayed.
Note: Some application program downloads automatically reset the
System Password.
Caution: If you change the System Password and then forget it, there
is no method to determine what the forgotten password is. Losing or
forgetting the password will block access to System Mode functions
and prevent you from requesting a download, performing remote
diagnostics, or changing any of the information already stored in
memory. The terminal can, however, continue to process transactions
in Normal Mode. If you forget or lose the password to your terminal,
please contact your local VeriFone representative for assistance.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Need to reset entry password on reczone password vault model 580
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html password cracker free
1helpful
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
2helpful
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top VeriFone Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
