it not freezing because it cooling system must be damaged,you bought another cooling machine it has mini size and it fixed at the point of older cooling placce.
I think you have tell wrong model .
Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid
Sliding Doors
Durable white powder coated, baked on enamel finish
Solid sliding top doors
Cord and plug included
Self-contained refrigeration system
Temp. range 0 to -18 degrees F
13.7 cu ft capacity
Heavy duty casters included
Dual drain plugs for easy cleaning
Environmentally friendly CFC-free R-134a refrigerant and insulation
115V, 4.5 Amps
51 1/2"W X 25 3/4"D x 34 3/4"H
One year parts, 90 days labor warranty plus 3 year compressor warranty
&2. Caravell GST-5213.7 cu ft Chest Freezer With Glass
Sliding Doors
13.7 cu ft capacity
115V, 4.5 Amps
Yes, the freezer / refrigerator is a heat pump, it transfers heat from the inside to the outside.
Heat transfer effitiance is reduced if the outside is at hight temperature, so it is sudgested to allow free air flow for the back of the cooling device (where the radiator is )
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
