ASUS P5N-E SLI Motherboard Logo
Anonymous Posted on Dec 04, 2010
Ever since I installed extra ram in slots 3&4 have had many Crashes.Windows 7/64 bit unstable.Ran windows 7/32 bit no problems.
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Dec 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
2158
Points
21
There is no problem with your hardware, but your software. I do not prefer using 64 bit applications/software since they are a bit unstable. Why not use just 32 bit since it has no problems?
We don't need to upgrade if we can't use it.
hehe
3helpful
2answers
Can i install windows 7 on acer veriton 7500g
Your Pc should meet the following hardware requirements in order to run Windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher drivers
I googled your pc model and found that you just need to install extra RAM (if your PC have less than 1 GB RAM).
Hi, I use asus Pro T5750 series with processor Intel core 2 duo 2.0 GHz with windows 7 ultimate OS 32 I have installed 2 x 2 GB RAM but see, Installed 4 GB (3GB usable) In Bios I see 4096 MB. How I can...
Hi Trifon,
you are detecting a known problem for 32 bit operating systems.
The problem for those system is that they can manage maximum 3 Gb of RAM.
If you want all of your RAM used you have to install a 64 bit operating system. Windows 7 has also a version for 64 bit as well as windows xp (but is not good supported) and windows vista.
2helpful
4answers
What is maximum ram i can install in Asus U50F laptop and what kind
Asus U50F has 2 memory slots (204-pin SODIMM).
Each memory slot can hold DDR3 PC3-8500, DDR3 PC3-10600 with a maximum of 4GB per slot
for a total of 8 GB ram.
Need to know where to install extra ram into my laptop and i already have 4gb installed Is there extra slots somewhere?
Before you install any extra memory, check the type of operating system and hardware you have and be sure it can address more than 4 Gb. 4Gb is XP's limit in 32 bit. Vista is pretty much the same and can address more but also only with a 64 bit system.
32 bit 64 bit
Windows XP 4 GB
128 GB
3answers
I have installed 4 GB of RAM but it only shows 3 GB RAM
Any 32bit OS can only read up to 3.5GB of RAM. In order to read additional ram you must have a 64BIT OS.
1helpful
Ram
Okay, you don't need two video cards. Your 4 memory slots are grouped in two's. One set is black and blue, and the other set is black and blue also. These are your dual memory channels.
The reason you can't see more than 2 gig ram is because you are probably not running 64 bit Windows with a 64 bit processor.
32 bit windows will only display 2 gigs, but max memory is 4 gigs. It will draw on the extra 2 gigs if ever it is needed, but this does not happen very often, if ever.
Hank
Promble with Ram
No the problem isn't the ram, or video card, or lack of video cards.
The problem stems from using a 32 bit O/S, (Operating System), like Windows XP Home, or Windows XP Pro. (The 32 bit version of XP Pro. Microsoft made a 64-bit version of Windows XP Pro)
A 32 bit O/S will only 'recognize' UP TO 3.2GB's of ram. (Sometimes up to 3.5GB's)
You need a 64 bit O/S so that your computer will recognize all 4GB's of ram, when it is installed.
32 Bit? 64 Bit? What is all of this? It's kind of hard to explain in a few sentences. I would like to refer you to these links on Wikipedia, to explain 32 bit, and 64 bit further,
A.32-Bit:http://en.wikipedia.org/wiki/32_bit
B.64-Bit:http://en.wikipedia.org/wiki/64-bit
RAM Upgrade
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
