Unable to recieve DHCP address via wireless
What should I do?
Model: 2650U/../D2
System log
Dec 4 15:30:06 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/8/35.
Dec 4 15:30:07 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/8/35.
Dec 4 15:30:12 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/8/35.
Dec 4 15:30:14 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/8/35.
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
You shouldn't be connecting the device directly to your ISP, but rather to a modem that is connected to the ISP. The modem will then handle the NAT for your network and your E4200 should be able to pick up a private IP address using DHCP from your modem. Or you can set a static IP on your wireless router as long as that address is available and on the same subnet as your modem. You should also exclude any static IP addresses from being handed out over DHCP so you avoid IP addressing conflicts.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
Power on the wireless router/access point.
Reboot the PC.
Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
Select LAN IP, and change the IP to 192.168.1.99.
Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
Log in to the wireless router/access point with the URL: http://192.168.1.99
Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
Configure the LAN IP address to be within the same subnet as your PCs.
Take care not to use an IP address already being used.
Limit the number of addresses in the DHCP range and assign an IP
address outside of the range to the router you want to use as the
Access Point.
Disable DHCP on the wireless router/access point.
Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
The IP address 192.168.0.1 you use with your browser is not to get into the Dlink WEB page, it is to get into the DLink router configuration, to set up the router and wireless security eg. network SSID, turn off SSID brocast, WEP/WAP encryption, MAC address filtering etc.
If not, and this is a wireless router, connect via ethernet cable and reboot the router, then reboot the computer. (You might can just try a command prompt and do ipconfig /release, then ipconfig /renew).
Otherwise, press the hidden reset button on the back of the router. You will be back at square 1, and will need to setup all of your security again, oif you had it setup.
are you using the router through a BT line? if you are BT will be able to sort this problem for you by sending the router an update that it sounds like it needs
If the SSID changed to the default then you know that the router reset to the default settings and you should set your computer to automatically get its IP address via DHCP. I always set up my routers through a Wired connection first, just to setup the router and then go with the wireless. The default for the router should be 192.168.0.1 and subnet 255.255.255.0 . If the computer is set with a static IP address, change it to obtain an IP address automatically or the network card will not bother even looking for an address.
Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration:
DHCP Client - Enable
IP Address ? 192.168.0.227
IP Subnet Mask ? 255.255.255.0
Gateway ? 0.0.0.0
Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227.
You can now try configuring the router through its web interface (192.168.0.227).
This is better explained in the user's manual available at the Netgear site (
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
