Hello download the driver here:
This is version 1,0
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=531&DetailName=Feature&MenuID=24&LanID=9
This is version 3,1:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=548&DetailName=Feature&MenuID=24&LanID=0#fragment-Download
Select vga and click on the download link.
Good luck
SOURCE: System won?t recognize SATA drive
No, the size does not matter. When you state the motherboard does not see the SATA drive are you saying the bios does not list the SATA drive? You're 750GB drive is most likely SATA 2.0 / 3.00BG transfer rate.
The P4M800-M7 does support SATA but it does not support SATA 2.0. So what you need to do to get the drive to function at a lower speed. Set to run Ultra 100/133MHz. You'll need help to do this. Try this software for Seagate. It might work for Seagate.
http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=126&orderNum=2
I haven't the time to research Seagates site for simular software.
However you can look through Seagate. Again you want to lower the SATA drive speed to Ultra. The bios will than see the SATA & so will windows.
http://www.seagate.com/www/en-us/support/downloads/seatools
Good Luck!
Mike
SOURCE: P4M800-M7
Hi jora, it is all based on what version you're motherboard is!
EliteGroup states the P4M800-M7 v3.1 does support the dual core CPU. (It does not mention this in the manual but does state this on their main web site for the motherboard P4M800-M7 (ver 3.1). (This link).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=548&DetailName=Feature&MenuID=1&LanID=9
EliteGroup, supported CPU's for P4M800-M7 (ver 3.1)
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=548&MenuID=69&LanID=9
However, EliteGroup P4M800-M7 (ver1.0) does not support dual core CPU's. (This link)
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=531&DetailName=Feature&MenuID=1&LanID=9
Supported CPU's (v1.0) (This link).
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=531&MenuID=69&LanID=9
So you need to find the version number of you're board.
Good Luck!
Mike
SOURCE: ECS 915-M5 mother board driver
here you can download all your motherboard Drivers:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=498&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
SOURCE: I have an ECS P4M800-M7 motherboard using Celeron
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:- http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
SOURCE: p4m800 m7 rev 3.1 & intel pentuim d 915 compatibility
Based on the information given here, the p4 d processor is supported by your motherboard. There should be no problem in making the switch.
