SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following:
1) take of the warmer plate on the top - 2 storz screws but an allen key works as well
2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess
3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front
4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly.
5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely.
6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free
7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel.
8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece.
9) You will now see the plugged spouts.
It goes back together really easily.
SOURCE: How do you turn on a Keurig to get a cup of coffee
I know on mine I have to open and close the chamber where I put my coffee. It then blinks ready and I press the size cup I want to brew. Hope this helps! :) And sometimes if there isn't enough water in the reservoir it won't brew so try and putting more than just a cup's worth of water in it :)
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day. I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
SOURCE: keurig does not brew the large cup of coffee, only
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
