Get it serviced the think is the heating coil may have got burnt out if you need to replace it remove the cover below and take out the coil carefully with the terminals ..now replace the coil of same wattage usually 700watts in the same way
there can also be a problem with some wire got burnt due to heating .try to find the wire located near/attached with the heating coil and check whether everything is correct
