HP Pavilion 533w (P9859AR#ABA) PC Desktop Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Put cd in ..green light comes on and then there is nothing. It has worked before ..
Brian Sullivan
Level 3:
  • HP Master 27,725 Answers
  • Posted on Dec 04, 2010
Brian Sullivan
HP Master
Level 3:
Answers
27725
Questions
Helped
5669194
Points
79191
Make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
WEll my CD driver suddenly stopped reading cd's I've tried putting different ones in put nothing happens i've tried uninstalling it and rebooting but still nothing .its starting to be annoying because I...
Does the cd drawer open by itself, or is it a manual pull out type?
Is there a green or amber light on the front?
You may have to get a new cd player and install it.
2answers
The computer willnt come on.The green light is on I CAN HEAR THE MOTOR RUNNING but nothing on the screen
hi,
try removing the battery and disconnecting the main power. keep idle for a couple of hours.fit everything back and try?
4helpful
Charging light not coming on
I had the same problem, took the thing apart and checked voltages with a multi meter the battery voltage was 1.5 volts checked all connections nothing wrong put it back together" no go" held the reset button for over a minute, lovely green flashing light! hope it works for you
1helpful
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at [email protected] or if you got anymore questions.
2answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
