Ryobi Multi-Volt Battery Charger Logo
Posted on Dec 03, 2010
Where do I get a Ryobi battery BEC 1263C? - Ryobi Multi-Volt Battery Charger
I have a P115 Ryobi Intelliport charger , will it charge the new lithium 18 V battery?
Ryobi P115 is an 18V battery charger. However, Ryobi Manual did not mention the current rating of P115. if the current rating of Ryobi P115 is 50% higher than your 18V Lithium Battery it will charge. but if it's less than or equal, it will not.
What is the charging time for Ryobi BEC-1263C battery
This depends on the capacity of the battery and the output current of the charger.
1helpful
2answers
Is there a recall for ryobi 18v charger or batteries
I had similar problems with my 18V Ryobi batteries. Called Ryobi customer service, gave them the serial numbers and was told there was a 2 year warranty on them, in my case the warranty was in effect until July 2012. Took the batteries to Home Depot today and they replaced my batteries with two brand new ones. I can't complain about Ryobi customer service
2helpful
18 volt batteries
Yes you can, as long as the batteries are the same style and fit the older Ryobi tools. The Ah rating is a capacity rating. The higher the Ah, the longer the battery will last so the 1.7Ah will just last a bit longer than the 1.5Ah batteries, but yes you can use them on older 18v Ryobi tools. I do it all the time.
2helpful
Lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
