Question about Sony DVP-NC85H Multi-disc DVD Player
Stuck in "loading" mode
  • pam7714 Dec 03, 2010
    I should clarify-this is a Sony portable DVD player-DVP-FX730. My kids each got them for xmas last year. One works fine and the other just started to stay in the "loading" mode for a really long time. Eventually it gives up and says that it can't play the disc. I have tried powering off, letting it hang out for a few days, etc. We have put in different discs-some brand new, and still the same.
  • pam7714 Dec 04, 2010
    So are there really repairmen to take these to out there in the world. How do I find them?
  • Sony Master
  • 6,993 Answers
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Posted on Dec 03, 2010
  • Walesarumi
    Walesarumi Dec 03, 2010
    I still think its a laser problem. The laser is responsible for loading data on discs and I believe its weak, that's why it cannot load discs.
    Take care.
  • Walesarumi
    Walesarumi Dec 04, 2010
    of course yes. Any electronics repairman should be able to fix this. look around for any local repairman within your vicinity/area and it should be fixed for you.
    In my country, this is very easy to fix.
    Take care.
SOURCE:
Frigdaire top loading washer # FFTW1001PW gets stuck in wash cycle. It agitates and drains but stays in wash mode. Is there a way to fix this?
possible problem program board not progressing
call in a technician for a proper diagnosis and quote
Sep 03, 2016 | Washing Machines
My MacBook Pro was acting a bit strange; some websites wouldn't load such as Google, yet Facebook would. So I updated it then coming to the automatic turn on after the update my laptop gets stuck on...
This sounds like a possible filesystem corruption, possibly due to a bad update from Apple. What is the error that "Disk Utility Repair" gives you?
You may be able to take it to an Apple store to get your data restored, as they (sometimes) have special tools that scrape the existing data from the filesystem even if the metadata is corrupt.
Jun 18, 2013 | Computers & Internet
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
Moved TV to a different room and the TV power button is blinking like it is in "standby" mode. How do I get it off "standby" mode??????
unplug it for about 30 mins it will reset it. if that doesnt work it will be stuck in standby mode until a video source is activated. if you are using hdmi both the tv and the hdmi device must be on. (hdcp compliant devices must be turned on at the same time otherwise it will say stuck in stand by mode they do this to prevent people from trying to rip content off hdmi and blu rays had the same issue with my tv and xbox.
Mar 14, 2011 | Televison & Video
My dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC TEST MODE 1. Make sure that the dryer is in the "Standby" mode (plugged in and all of the indicators are off). 2. Press the following control panel keypad sequence all within 5 seconds: More Time-Less Time-More Time- Less Time. 3. All indicators on the console should now be illuminated with "88" showing in the "Estimated Time Remaining" display, if this test mode has been entered successfully.
Dec 26, 2010 | Whirlpool Duet Front Loading Dryer Rack...
When attempting to start my computer this morning it took me to the safe mode screen ("We apologize for the inconvenience but windows did not start successfully. A recent hardware or software change...
open your computer in a safe mode then save important files in pen drive or some removable drives....or scan it in safe mode with updated antivirus......or updade windows or repaire windows using installation process...........this will definatelly works..........
Nov 13, 2010 | Computers & Internet
Sony DVP-NC85H Multi-disc DVD Player Logo
477 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
