SOURCE: htc touch diamond freezes on start-up
I called and spoke to HTC ..apaprently there are issues with some of the handsets .. and its power related ... the best this is to do 2 things to solve any number of issues....
A: Get a replacment battery, and recharge it fully without turning the phone on. So plug it in and charge it until the white pulsating light is fully lit and not 'breathing' ..as they say. Once fully charged then turn on your phone...
B: Once on ... 'hardware' reset it - (you turn on the phone, holding the volume down button, and the hang up button and pressing the 'software reset button, at the same time)
Should solve it ... IF it dosent .. and your getting the same issues after battery replacment, software and hardware resets ...you've basically got a 'hardware' issue with the phone in which case you need a replacment or repair... (make sure your phone is insured)
Hope that helps folks...
p.s.
My phone eventually stopped charging ...nothing, no power so i sent it back for a replacment which im waiting for to arrive...
SOURCE: how to unlock Htc Touch Diamond !!
follow my shared experience to ulock HTC Touch Diamond. Was locked with Orange operator in UK
http://internetbisnisonline.co.cc
over at xda forum the scumbags are charging people for the unlock software i got free from a german friend. this definatly unlocks htc touch, diamond, pro exc its really tricky to excute the last stepsbut it definatly works. all you need to do is join this site free and search for diamond_unlocker or browse through our ppc setion you will find it as i said its free of charge to join and download instructions are very easy to follow after you have completed steps 1-3 you need to flash a new radio. http://www.extremplanet.co.cc/forum/
SOURCE: how do I change my HTC Diamond windows mobile 6.1
did you try going to> start>settings>system>regional settings. then select region and reboot phone
SOURCE: My HTC Diamond Touch Screen wont work
Sane happened just on my diamond. I heated it alot in my hands, then i turned it on, when the red text came in the start i pickt out the battery. Inserted it again and started the phone. Then my touch was acting up with pushing 4 all the time. That was a good sign, at least the touch was still working. Then i hitted it some times, sounds stupid but then i got it working again. The battery solution was helping the most, but hitting it softly also helped with the 4 button problem.
Hope this helps some of u out there with the same problem.
Klovnen
