Model 50PC1DR bought 1 year ago couldn't afford warranty, now it turns itself off 2 sec after I turn on. Fan makes humming sound. tv was very dusty we live in a rural setting with fine red dust. I am a fostermom was the first tv I bought for my pleasure , please help
Thank you Inger
SOURCE: 42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
SOURCE: I have LG 50PC1DR plasma
Without testing I wouldn't suggest the Power supply is not defective: 1st, the control module is working because you gave it an ON command, 2nd the SMPS has received the the start up. The secondary voltages for the Y sustain and Z sustain modules are shutting down, probably due to a shorted IPM on either of the two modules mentioned. This problem is one you should contact your nearest svc center for a complete diagnosis. If I can be of any other assistance please e-mail me.
SOURCE: LG 42PC1RR No picture -- only sound !!
yes i have had many problems with my lg plasma. i had to replace three boards in the back of the tv. it is most probably the y sus board which has failed.
