Unplug, every thing, take batteries out of remotes etc, remove power from all parts.I mean every parts. leave out for about a minute. reconnect all. try then
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
disconnect the connector and have a friend push the washer button while you check the wires for power with a test light.its probably a bad motor, they are about $15.00
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
When a motor hums, it usually is the result of what is called "locked rotor." This can occur when the motor's brushes remain on one pair of the commutator contacts. The magnetic field does not shift to the next set of windings and the rotor is locked in place by the unchanging magnetic field.
If you have access to the motor, turn on the power briefly and place your hand gently on the side of the motor. Probably you will feel the vibration of the hum you are hearing, together with some heat. In locked-rotor condition, the motor draws high amperage and heats up quickly. Turn off the power.
If this is the condition, the motor is shot and needs to be replaced. You should copy down the information from the name plate (model and serial number, manufacturer, horsepower, amperage, etc.) and contact the manufacturer or a local appliance parts store about a replacement.
As you said that you recently bought the house, you may have a home-owners warranty which may cover the appliance.
