Clothes are very difficult to iron when they are fully dry or over-dried in the dryer. Over-dried clothes are resistant to reshaping, which it exactly what ironing is. Removing clothes when they are still slightly damp will make ironing much easier. If you line-dry your clothes, bring them inside to iron when they are not quite dry.
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
I am having the same problem on a WD9900A. The wash cycle works great. Spins fast and clothes are completely rung out. Dryer cycle heats up well. Fluffs and heats cloths. At some point during dry cycle water is injected on clothes and they end up sopping wet; much wetter than after wash. Filter is clear. Outlet pipe clear and functions well. Possible problem with dryer timer? Or washer timing kicking back on?
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
