Hi there! The first thing you need to do is to check if you phone cable is inserted in the right port.There are two port for the fax.the first one is for the phone line and the second one is for additional phone.The second thing you can do is to change the cable with another one and try again.The last thing you can try is to connect a normal phone to that line and check for noise while moving the phone cable.If there is noise on the line,then you need to call a phone line tech. to check you cables.Please replay if you need any futher help!Thanky for using Fixya
Make sure that you have settings to RECIEVE FAX.
Go to start on your Desktop. Click on All Programs. When window opens, click on accessories. When accessories window opens, click on COMMUNICATIONS. When the Communications window opens, click on Fax. When the Fax window opens, click on FAX CONSOLE. When the FAX CONSOLE window opens, click on RECEIVE FAX NOW.
You might have to wait until your telephone/fax machine, rings and then click RECEIVE FAX NOW if it does not work automatically.
The person who is sending you a Fax might have to inform you they are sending a Fax to you right now.
Hope this is helpful to you. Good luck.
