Sony PlayStation 2 (PS2) Console Logo
Posted on Jun 26, 2008
Slim ps2 disk read error
I've been trying to find out how to fix the disk read error on ps2...system will not read any disk...new or old....any help would be appreciated.
thanks
  • Anonymous Dec 23, 2008
    MINE IS THE NEW ONE AND IT DOESN'T READ A DISK i JUST GOT IT SIX MONTHS AGO AND IT DOESN'T READ A THING
  • crueboysaten Dec 23, 2008
    my ps2 wont play any games. i even bought a brand new game and it still wouldnt play it. it will read it but wont play it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jun 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
1641
Points
28
I don't want to put you down or nothing but, buying the slim ps2 wasn't a great idea. If you bought the original ps2 it would've been better. The thing about the thin ps2 is the hd is small, the laser tends to become weaker faster. Go get the ps2 checked out someplace.
2answers
My slim ps2 story
something must be wrong from the ps2 not the game silly
2answers
Please insert ps2 format disc?
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
Playstation 2 stopped working
It sounds like the disk reader could be damaged. PS2 is an old console so I think it is just dying. You could try this. How to Fix PS2 Disk Read Errors
2answers
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Sony slimline ps2 NO DATA
the ps2 slim gets disc read error alot. this issue can be fix by replacing the laser in the system. make sure you get the correct laser
I keep getting a "Disk Could Not Be Read" error.
maybe the lens of ur ps2 slim are dirty...if not you may need to replace it, coz lens get weak after a long time of stress using it...
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
3helpful
My PS2 Slim plays music, black and blue discs, but doesn't play silver discs nor DVDs.
Is this a new problem or has your PS2 always had this issue? You cannot adjust the laser at all and are likely to damage it if you try, you can however clean the laser lens with a CD/DVD cleaning disk and you'd be surprised how often this resolves disk read issues. Some of these units did have a production fault that prevented them from reading DVD's, if your PS2 has had this fault since new and/or is under 12 months old you could probably have had it repaired/replaced by Sony but by opening it you will have invalidated you're warranty.
65helpful
43answers
Disc read error
To fix this problem, you will need to open your PS2 and re-adjust its lens. To open your PS2, first turn it upside down. Remove the 4 rubber feet and 6 square tabs (circled in the picture) by sliding a flat screwdriver (or something similar) underneath them.
1helpful
7answers
New game won't play.
the problem with god of war 2 is the ps2 lasers are not capable of reading the dual layer disks. either wait and get a ps3, change the laser - i just bought on for 3 quid on e bay brand new. the lasers are not designed to be played the amount they are played. the laser is designed to play 20 hours a week but as sony found out he avg gamer will clock up up tp 60 hours a week so the lasers are only lasting 1/3rd of the time they should. plus if they put a good laser in the machine u would one buy 1 ps2 and then 1 ps3. i have burned out 3 ps2's so far lol. just forget the game or wait till its put on platinum as these are single layerd disk
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
