Computers & Internet Logo
Posted on Jun 26, 2008
I have a casio fx-83es calculator.If I type in for example 87.67 34.56 , the answer will display as a fraction. I am aware how to get it in decimal form after hitting certain buttons but, As I am constantly dealing with such numbers how do I turn off/change this feature so it will display the decimal number as my answer initially. Kind regards, JS
  • SamWat Jun 26, 2008
    *Correction the example is, 87.67+34.56
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
689
Points
42
Doubt you're still having this problem as its been months....figured id post for people who stumble across this from google.
Click on the shift button in the top left, then select the mode buttom (second from top right), then press the number 2. This should switch the calculator onto linear and will give you answers with decimal points.
Regards,
hopper84
1helpful
CASIO fx-9750GIII: Convert decimal answers to complex fractions?
to save time, I would suggest switching calculators and also recommend using an online scientific calculator to reach your goal. If the manual for your device is bad, you can look into getting a new calculator. Thank you.
My new casio fx-300ES calculator outputs answers as a fraction... how can i change the output to a decimal point?
To change a displayed result into a fraction, press the [S=D] key.
To force a result to be displayed as a decimal number before it is displayed, press [SHIF][=] instead of [=].
7helpful
How do i change from getting answers in fractions to decimals on a casio fx-83ES?
Change the Input/Output Mode to LineIO. Press [SHIFT][MODE] and select [2:LineIO].
2helpful
2answers
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
3helpful
2answers
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
1helpful
2answers
Changing decimals to fractions
You can always convert a fraction to a decimal. The reverse may not always be possible. Look at the example on the screen capture.
You may be lucky and recover a fraction you have just converted into decimal format, but you cannot just write 0.333333333333 and expect the calculator to convert it to 1/3: The true fraction 1/3 has an infinite number of 3's after the decimal mark.
2answers
Casio fx-83
press mode untill u see FIX and then the numba of decimal places u want
14helpful
10answers
Casio fx-83ES
there is a button SD close to AC button, standard - decimal try it .......or
shift+mode format math IO, change it to the other option
Grand Canyon Tech
Grand Canyon Tech
