Hi, you will need to reinstall the wireless card drivers, if this came with wireless as standard you should be able to download the drivers from the manufacturers support website, if it was added later on then it should have came with an install disc with the drivers on it.
Hope this helps
John
Windows XP Wireless Auto Configuration
Windows XP Wireless Auto Configuration, enabled through the
Wireless Zero Configuration service, provides a way to automate the
configuration of the settings for wireless networks. When your wireless
network adapter, whose driver supports Wireless Auto Configuration,
scans for wireless networks, the names of the found wireless networks
are passed to Wireless Auto Configuration. Windows XP maintains a list
of preferred wireless networks. Windows XP tries to match a found
wireless network to the preferred networks list in the order of
preference. If a network name is found, Windows XP uses the settings of
the wireless network to attempt a connection. If a network name is not
found, Windows XP prompts you with a notification bar message, asking
you whether or not you want to connect to one of the found wireless
networks.
For home or small office wireless networks, you will use
Wireless Auto Configuration to discover your wireless network, but
because the default configuration for a wireless network is to use WEP
and automatically determine the WEP key, you will have to manually
configure the settings for your wireless network.
This is per Microsoft xp information!!!
http://technet.microsoft.com/en-us/library/bb457016.aspx
