D-Link DIR-625 (790069292637) Wireless Router Logo
Anonymous Posted on Dec 03, 2010
Just purchased a Vizio 37" HDTV with Netflix app
  • 1 more comment
  • Anonymous Dec 03, 2010
    The Vizio 37" Model XVT373SV has wifi and all apps work except netflix.
  • Anonymous Dec 04, 2010
    DIR-625 - D'Link says not update I have Firmware 1.09 Hardware Version A1
    Changed setting I could the following settings I do not have
    Advanced - Firewall Setting - Uncheck - "Enable anti-spoof checking"
    Advanced - Secure Spot
    Set-Up - Internet - Manual Internet Connection Setup - Uncheck - "Enable Advanced DNS Service"
    Set-Up - USB Settings
    Tried Netflix still does not work
  • Anonymous Dec 06, 2010
    Wondering if you received my reply on Thursday Night.
    Thanks Bill
JDTec
Level 3:
  • D-Link Master 4,338 Answers
  • Posted on Dec 03, 2010
JDTec
D-Link Master
Level 3:
Answers
4338
Questions
0
Helped
2127926
Points
14653
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
  • 3 more comments
  • JDTec
    JDTec Dec 03, 2010
    What model is it? I Will research it.
  • JDTec
    JDTec Dec 03, 2010
  • JDTec
    JDTec Dec 03, 2010
    Try these settings on the router
    Under Advanced --> QOS engine --> QOS engine setup
    Uncheck "Dynamic Fragmentation"
    Advanced --> Firewall Settings
    Uncheck "Enable anti-spoof checking"
    Under Advanced --> Advanced Wireless -->Advanced Wireless Settings:
    Uncheck "Short GI"
    Under Advanced --> Secure Spot
    Uncheck "Enable Securespot services"
    Under Setup --> Internet --> Manual Internet Connection Setup:
    Uncheck "Enable Advanced DNS Service"
    Under Setup --> Network Settings --> Router Settings:
    Uncheck "Enable DNS Relay"
    Under Setup --> Network Settings --> DHCP Server Settings:
    Check "Always Broadcast"
    Under Setup --> USB Settings:
    Set "My USB type" to WCN Configuration
    Under Setup --> Wireless Settings --> Manual Wireless Network Setup:
    Set 802.11 Mode to Mixed n,g,b
    Check "Enable Auto Channel Scan"
    Set "Transmission rate" to Best (automatic)
    Set "channel width" to 20
    Set "Visibility Status" to visible
    Or:
    Updated the DIR-625 router firmware
    reserved the "static" IP address of theVizio in the DHCP server so nothing will get that address.
    set the Vizio IP for the router's DMZ.
    set port forwarding for 32768 TCP and UDP -
    make the static IP changes on the Vizio and set the DNS to 208.67.222.222 (which is resolver1 at opendns.com)
  • JDTec
    JDTec Dec 06, 2010
    Received your reply, According to Netflik , that should have worked. The only other suggestion I have is to reset the D-link and try it before setting any encryption or Port Forwarding. Just. use the TV and Dlink only, just to see if there is something other that is blocking NetFlik.
  • Traewhitfiel Dec 26, 2011
    I need help with my Vizio 47 inch it won't connect to Netflix.
I am a member of netflix how can i watch movies on my tv
You need a connected tv that has an app for Netflix or buy a dvd/bluray that has connected tv apps built in. I have a Sony bluray and am able to watch netflix, amazon Prime video and youtube on my tv through this bluray
How to activate netflix on my vizio smart tv
Hello friend...
Just follow these steps:
1.Press the Vizio Internet Apps button on your remote (located immediately beneath the red, yellow, green, and blue buttons, below the arrow buttons).
2.Select the Netflix app.
3.Press Ok.
4.Select Sign In.
5.A code will appear.
For any help visit us: Netflix Com Activate
11helpful
2answers
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
1helpful
D-Link DIR-625 can not broadcast wireless continously
LOOK AT BACK OF LINK BOX FOR A SMALL HOLE WHEN FOUND TURN POWER OFF ON BOX PUSH TIP OF PEN INTO HOLE THEN TURN POWER BACK ON THIS WILL RESET MEMORY
1helpful
2answers
Connecting to Netflix with a Roku video player
What is the exact error message??
Are you unable to connect to LAN or Internet Or Wireless network
1helpful
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to http://portforward.com/english/routers/port_forwarding/Dlink/DIR-625/DIR-625index.htm
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at http://portforward.com/
Enjoy,
FixThemAll......
Cannot connect
The vista is wireless?
Right click the computer icon on the bottom right hand>click connect to a network>then click network and hit connect if its secure it will ask you for the security if not just click connect anyway.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
