Frigidaire PLMV169DC Microwave Oven Logo
Anonymous Posted on Dec 02, 2010
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
Anonymous
Level 2:
  • Expert 130 Answers
  • Posted on Dec 02, 2010
Anonymous
Expert
Level 2:
Answers
130
Questions
0
Helped
45233
Points
733
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Testimonial: "Quick and accurate! Will go ahead and replace the entire unit. Thanks REPAIRMAN45!"
  • mkoithan Dec 25, 2010
    Mine is also 3 years old. Same issue. I suggest that all of us (there are many with this issue -- units less than 3 years old) write and complain and get this recalled. This is not the first Frigidaire Professional Series manufacturing issue. The oven that goes with this set (manufactured at the same time) was just recalled too.
  • ajmayer Apr 15, 2011
    you have got to be kidding me. we have the same exact microwave and it has the same exact issue. its less then 5 years old.
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 1 yr...
If it's less than one year old, it would be fully covered under warranty and you should contact the manufacturer to get it fixed free.
Some have longer warranties, and that will be covered in your owner's manual.
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
19helpful
2answers
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
