SOURCE: Problem with HomePride model TE555 fireplace heater
I hav ethe same heater but my coil does not get hot. I am trying to find a replacement part for it but no luck. I called the number (905-847-2643) of the company but no call back.
SOURCE: Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
SOURCE: I need a new flicker motor for my heat surge
If you have the old motor in your hands, go to www.grainger.com and they can cross ref. with the name plate data on it, and replace it for you.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: Charmglow fireplace, everything on, no heat
its either a sensor or the element most times sensor or limit.
