Master
- Posted on Dec 02, 2010
Re: Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15db
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Dimensions: 19.7"L x 9.25"W x 2.36"H
