The sequoia hatchback handle breaking is a known problem due to the extremely low quality of the plastic. 1st you have to open the back door! there is a small pin to the right side of the hatchback door exterior handle. bend a coat hanger and put it on the small pin, pull down and the door will open. Then remove inside panel and you can undo screws and replace the hatchback door handle.
Http://www.tundrasolutions.com/forums/1gen-sequoia/40507-rear-latch/
Look on this link this is a common problem toyota has.
best of luck
SOURCE: 1998 toyota 4 runner back hatch handle broken
get inside the back take door panel off mipulate door latch to open
SOURCE: Broken rear hatch door handle on Toyota Sequioa
It sounds like the handle has become disconnected from the mechanism. You will have to remove the inner door panel and reattch. It is not a complicated or difficult job but if you get a professional it could cost upwards of $100.
SOURCE: Cannot open hatch door
Remove the hatch interior cover...you can remove the broken hatch handle that way...also open it from there.
