REVERSING DOOR SWING
Your
dryer is designed so the door swing may be reversed at any time without
additional parts. Conversion is accomplished by transferring hinges to
the opposite side of the cabinet.
To change the direction of the door opening:
1.
Open the dryer door. Remove the four hinge hole plugs from the left
side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Testimonial: "Thanks, this is just what I thought, without having looked at it. Very helpful. Dennis"
DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
We have 15 years developing experiences and will implement the advanced products to our customer.
Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
* Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
* Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
* Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
