SOURCE: I have a panasonic NNA883w
If
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
You can find an authorized Panasonic servicer here.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven.
Most people don't, for this reason, replace the magnetron, they replace
the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the
magnetron is faulty and you need to take it apart, find the proper
electrical leads and test them with a volt meter. To do this you have
to remove it from its mounting and take it apart. It is a fairly
lengthy process however.
Benjamin
SOURCE: Have a Panasonic Microwave/Combination
I could not find your exact model but please check out the link below and download the one that is closest to yours.
Hope this helps. good luck
http://www.panasonic.ca/english/customercare/downloads.asp
SOURCE: Grill element stopped working.
I had the same. Dismantle the oven and see at the back side the connection wires for the heat element. Mostly one of the connectors is faulty. I fixed it that way.
SOURCE: sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
Testimonial: "thanks for the quick reply, ya even i think so that the problem, but i had no idea how expensive a magnatron is and where to buy it. do you know?"
