Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions: http://www.ehow.com/how_2106008_use-coleman-stove.html https://www.youtube.com/watch?v=dbYil-YQ8-Y
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Hi bearsmommy19...
Yes you can use a generic regulator/coleman on your brinkman...just make sure the threads all match, if not, then adapters in brass can be bought at the local hardware HomeDepot,Lowes,etc.
Then you can install them to adapt your regulator to your brinkman grill
Please take time to rate me
Ozark Trail GCT1705W Portable 2-Burner Double Propane Gas Stove replacement parts ARE NOT AVALABLE ANYWHERE !the only thing you can do is get a coleman regulator part number 5430 regulator .cut you tube and hose clamp it to the new one ! use a 5/16 fuel line use 4 clamps on each sides ! these stoves are junk and we are bot stuck with them :( this way beats throwing the piece of junk out ,then you will have a usable stove with a coleman regulator
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.
thanks will look into info sent thanks
