Question about Apple iMac G4 Desktop
Fix a vertical line on a imac - Apple iMac G4 Desktop
2 Suggested Answers
SOURCE:
  • 23 Answers
SOURCE: Colorful vertical lines on 17"
This is typically a bad or loose cable to the monitor inside the computer. While you can open the iMac, Apple doesn't make it easy. It requires special tools, and there is a lot of tape involved. You can go to an Apple store to get it fixed, or to most computer repair places. It will likely cost you a little more than doing it yourself, but if something gets messed up in the process, they will be on the hook for fixing it, while if you did it yourself, now you have two things to repair.
Posted on Mar 08, 2011
Yellow stripes on imac (early 2009) display
Some of these links may help:
http://mac.bigresource.com/iMac-display-has-yellow-vertical-line--O9EU1eiuu.html
Dec 29, 2012 | Apple 20" iMac Desktop
My iMac has had a reappearing yellow vertical line down the left of my screen for at least two months now!
Maybe the video card. Try to spray with electronic contact cleaner the connections (pc cable to monitor).
Aug 01, 2012 | Apple iMac Desktop
Feb 06, 2011 | Apple iMac 17" Desktop
I wrote a while ago saying that i had lines running up and down my iMac I have not heard back yet and now have a fourth line.
Generally, vertical lines running down the screen are a sign that the LCD is beginning to fail. It will only get worse the more is fails. I would recommend taking to an Apple Store, if you are under warranty they will fix the problem. If you are out of warranty, the cost isn't too high, less than $400 to replace the LCD in the computer.
Jan 29, 2011 | Apple iMac Desktop
Shortly after the warranty was up the first vertical yellow line appeared and now, about 1 months later another vertical line appeared. He's not happy to hear it only gets worse and apple won't do anything...
Although its possible for graphics processor failures to cause vertical lines, they more often create horizontal ones. The first culprit to check for a vertical line problem is the LVDS cable, which it turns out is not that expensive a part (not counting all the work there is in getting to it). To verify this, I would gently flex the cable while the iMac is open and operating, and see if the lines get better or worse. It may also be that the cable itself is fine and just a few of the connector pins at either end are intermittent, in which case it just needs reseating.
Oct 18, 2010 | Apple iMac G5 Desktop
I have an iMac 17" that has just started to have a vertical line - blue in color. How can this be fixed? It's 3 years old and nowhere near a technical support person.
Hi this is a known problem and will terminally get worse with the only solution being to get a new screen being over £300's.
heres someone who could help you http://www.gumtree.com/london/54/66321154.html
Sep 30, 2010 | Apple iMac 17" Desktop
A fine vertical blue line running through imac screen
How long is a piece of string? is the kind of question you've asked. I've a sneaking suspicion you'll get sick and tired of it before it finally goes.
Jun 03, 2010 | Apple iMac G5 Desktop
I have an iMac (version 10.4.11)....and have the vertical line problem. There are two thin vertical lines on the left side of the screen and a pink line down the middle of the screen. Is this problem...
the lcd is bad,for some strange reason this is becoming common with Imacs.I recently repaired about 30 with the same problem.The techs at apple wont say why this is hapening they prefer to replace parts.In your case you will have to replace the lcd display and the cable from the display to the logicboard and not the logicboard.
Good luck
Aug 31, 2009 | Apple iMac G4 Desktop
COLOR VERTICAL LINES.
Vertical lines are problems that usually arise from either a bad lcd or video card ( GPU).
There is no fix, other than replacing the bad part.
If you want to do it yourself I've got service manuals, but unless you have experience it's no walk in the park.
Is it still under warranty?
You might be able to get an extended warranty through AppleCare.
Feb 27, 2009 | Apple iMac G5 Desktop
White vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Dec 15, 2008 | Apple iMac G5 Desktop
Apple iMac G4 Desktop Logo
236 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
