SOURCE: Wiring Fault light
You can download the manual from the link below: http://www.sourceresearch.com/cyberpower/cyberpower-pdf.cfm?PdfPage=625_Manual.pdf The "wiring fault" could be serious, as per manual: "This LED indicator will illuminate to warn the user that a wiring problem exists, such as bad ground, missed ground, or reversed wiring. If this is illuminated, user is advised to disconnect all electrical equipment from the outlet and have an electrician check the outlet to insure proper ground." I would turn the UPS off, unplug all equipment, wait 10 seconds, reset the circuit breaker (if tripped) and turn the unit on. If you still have an issue then it's probably fried! Have you had any thunder storms or electrical power outages recently? Check your house insurance because it may cover a replacement unit. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: i have a 1991 olds cutlass cierra. code 26 quad
THE QUAD DRIVER IS BUILT IN THE COMPUTER.I WOULD REPLACE THE COMPUTER THEY ARE NOT EXPENSIVE ON YOU VEHICLE.LOCATED RIGHT FRONT INSIDE KICKPANNEL!
SOURCE: How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
SOURCE: Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
