The HP Printer light flashing after replaced the ink cartridge with new one. There are various reasons behind the issue HP Printer lights blinking:
·When you have paper jam or empty paper tray
·Incompatible ink cartridges
·Printer print head clogged nozzles and more
Follow the steps to fix HP Printer lights flashing issue.
Thank you all of you, you solved my problem
Did you replace orginal HP cartridge? if you are change refill or any other kind of manufature cartridge , there is chip is not working properly, that's why ligh is blinking, use orginal HP toner or good quality brand
SOURCE: New printer cartridge light still flashes printer
clean the contacts of cartridge carrier (the place you put cartridges in ) with a wet towel
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Testimonial: "Thanks!"
SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
SOURCE: lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Try removing the toner cartridge and putting it back in place.
Try also unplugging power cord for ten minutes, and check if this clears error message.
Inspect the printer for foreign objects, or paper stuck inside.
If this does not work, it is a faulty drum.
