Changes in software, settings, or
drivers can cause a microphone to stop working. Before performing any of
the solutions in this document, test the equipment. After testing the
equipment, select the document section that applies to the issue and
follow the instructions.
If the
microphone recently stopped working, it may be necessary to use the
Microsoft System Restore feature to correct the problem.
Windows Troubleshooting
Windows
troubleshooting can automatically fix common problems with your
computer, such as audio recording. Although it may not fix every
problem, it is useful to run Windows Troubleshooting first before you
manually correct problems. To run Windows Troubleshooting, follow these
steps.
If a recommended action displays, select Apply this fix
or Skip this step
to continue to search for other problems. If your problem has not been
resolved, continue to manually troubleshoot using the rest of this
document.Test the equipment
Verify that the microphone port and the microphone are working properly.
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the
SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for
recording (as opposed to un-checking mute in the playback
controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the
2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and
place a check against microphone in the list entitled
'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
