I have a Toshiba DVD video recorder D-KR10KU and I want to know if I can record from two different channels when I set up the timer recorder? Or, am I only able to set it up to time record one channel. When setting up the time record you are never asked what channel you want to record from. On my old VCR you could record from different channels at different times because when you set up the recording it asked what channel you wanted. My current DVD recorder doesn't ask that question when you are setting it up to record different programs. What is up? Am I just out of luck or what? Thanks...
  • jdboise4 Jun 25, 2008
    Not the answer I wanted to hear, but it was the correct answer. Thanks for your help. Good job...
    Genius:
  • 2,028 Answers
Unfortunately on this model you don't have the channel option for recording. Only one channel at a time, sorry.
Posted on Jun 25, 2008
SOURCE:
It will not timer-record some channels such as Channel 5-2 and 9-2. I can manually record on those channels, but when I try to record using timer programming, it won't record those channels.
If Toshiba offered you a refund due to the alleged bug, I doubt that there is a work around to the problem. If it had been a regular tuner I would have suggested that you scan all the channels to commit them to memory.
The problem basically is that those channels re not in the recorder's tuner memory. You can enter them manually but when you try to use the programming the unit will not do it since channels are not in memory. Check your manual to see if there is a provision for getting channels into the memory of the unit. Don't hold your breath.
Sep 10, 2015 | Toshiba DVR670/DVR670KU DVD/VHS Recorder...
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
Recording Multiple Channels with DVD Recorder
Yes just set the timer programs on each line in the set timer "page". You just change the date and times on each line in order.
Aug 02, 2009 | Philips Magnavox DVD/VCR Dual Player
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
HELP
I am trying to set the timer record to channel 185, but my unit will only allow me to set to channel 125.
Apr 15, 2008 | Toshiba DR550 DVD Recorder
Timer programming problem
Check to see that you have not changed the default choice for input on power up of the box the "timeshift default device". If you have it set to front or rear CVBS or S-video input, it may ignore the channel choice you make when setting up the recording.
tom
Feb 13, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Ekse
