Video Cameras Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My DXG luxe ultra-thin camcorder will not read the 2gb SD card, what is the problem?
Anonymous
Level 2:
  • Expert 173 Answers
  • Posted on Dec 01, 2010
Anonymous
Expert
Level 2:
Answers
173
Questions
0
Helped
46191
Points
433
Hi! the possible problem for this is in your SD memory. Try to fix your SD memory card by formatting it. This will solve your problem
I have a DXG 5B1 HD and need to replace the card. What specific card is compatable?
As per this page:
DXG USA DXG 5B1V HD DXG Sportster 1080p HD Underwater Camcorder
SD Card (Up to SDHC 16GB Class6)
This is probably one of the best you can buy:
SanDisk Ultra 16GB SDHC Class 6 Flash Memory Card Speed Up To 30MB SDSDH...
If you don't need 16GB, you can buy cheaper cards with less storage space.
Can I update the OS on a DXG 305v digital camcorder to be able to read more than 512 MB? Can it even read and HCSD chip?
I assume you mean SDHC. DXG does not have a firmware update for this camera. The differences between SD and SDHC involve hardware. If a device was designed to work only with SD cards and not with SDHC cards then no amount of firmware updating will change this.
When you insert a new 2gb sd card and the camera message reads card full.
The card may need to be formatted, or it may be that this camera does not support so large a memory card.
WHEN I TURN ON MY DXG 505V THE SCREEN ASKS FORMAT SD CARD? I ANSWER YES. GOES BACK TO DXG ON SCREEN AND KEEPS REPEATING ITSELF ABOUT THE SD CARD. AND SO ON
Most likely cause is the the SD Card is the wrong type. There are different types in the same size card.
Some cameras can only take a card to a certain volume in GB. You put a 5GB card in a camera that is only rated to 2GB and you will get an error.
Make you the Lock Protection tab is set to unlocked.
Remove battery, wait 2 minutes and try again.
The manual says this regarding format failure
The digital video camera cannot guarantee to perform formatting on all memory card formats. When this happens, please format the memory card on a PC as the FAT format.
Speed Class - SD Association
www.sdcard.org > developers > overview > speed_class
The SD Association has defined various Speed Class standards to answer a ... If your host device requires a UHS Speed Class 1 SD memory card, you can use ... ‎SD Family · ‎Capacity (SD/SDHC/SDXC · ‎Application Performance Class
How to choose an SD card: Class and speed ratings explained
www.expertreviews.co.uk > SD Cards
Aug 23, 2019 - The SD Association devised a way to standardise the speed ratings for different cards. These are defined as 'Speed Class' and refer to the absolute minimum sustained write speeds. Cards can be rated as Class 2 (minimum write speed of 2MB/s), Class 4 (4MB/s), Class 6 (6MB/s) or Class 10 (10MB/s).
microSD and SD Card Buying Guide - TechSpot
www.techspot.com > guides > 1591-microsd-buying-gu...
Jump to Speed Classes - Class 2 (C2), 2, Standard definition recording and playback ... Some SDHC and SDXC cards will also support Ultra High Speed
Help on DXG-505V
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02MmcbrEuTOz2sgO3pG9VOviV1Prg%3A1607448429463&ei=bbfPX73aG8K1ggfW2o_AAg&q=dxg+505v+format+card+failure
DXG-565V Flash Media Camcorder: my DXG -565V Flash Media Camcorders sd slot wont e...
There is a spring that puts pressure on the SD card. It is most likely stuck.
You will need to fish around with a straightened paperclip, but be careful not to bend anything or the slot won't work properly any longer.
this has happened to me a few times and it's always the same fix...the spring is jammed and needs to be coerced back into place.
Hope this helps!
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
My sdhc card wont work
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
2helpful
My camera won't turn on!
Check your memory card you need a sd card or mmc for this camera make sure your card is not an sd hc card over 2gb it will not support it
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
